reset crop toll and transform tool
Mads Juul
Post by Mads Juul »
When I select the crop tool and the transform tool it has the setting from the last time I used it
is it possible to have it reset every time I select It?
Or is there a shortcut for this so I can make an action where i select the crop tool and then reset
or can I do it with a script?
-mads
Re: reset crop toll and transform tool
? both panels have a reset button.
Mads Juul
Post by Mads Juul »
Yes I know, But I want it to be reset when I SELECT the crop tool with my key command.
now I select the crop tool. the i have to go to the menu and press the button.
which is a little annoying
I want it to be reset every time I select it
-mads
I remember well when what you are asking for was the way the crop tool worked and it drove quite a few people nuts. Specifically dhomas trenn was very adamant about it being changed so that the tool would remember its last setting. When this change was finally implemented, there was an audible sigh of relief that could be heard around the world.
oh i see.
i specifically asked for the transform tool NOT to reset every time i use it (this was the previous default)
so the solution would be to either make these resets assignable to a key or to make the default behaviour an option in the preferences.
Mads Juul
Post by Mads Juul »
Well There is a reset for the "Tools Brush: reset"
It could be nice if it worked with the Cut tool and transform tool too
then I can make an action for my need, because I can see the sense in NOT resetting the tool
-mads
Mads Juul
Post by Mads Juul »
And it doesnt seem That Im able to access and set the settings for the Crop tool through scripting.
if I use "Tv_getActiveTool"
It switches to the FreehandLine shape and selects the penBrush
that pretty weird after my opinion :wink:
-mads
dhomas
Post by dhomas »
I'm actually a little frustrated with the crop tool. I don't know when it changed (after Mirage?), but it used to be that you could use the mouse buttons to size and position the crop area, without having to click on the tiny little sizing boxes. The old method was much faster to use. Maybe there's a setting in the prefs for this? If not, there should be. :-)
For information about youngmonkey software for Windows, VT/TriCaster, and TVPaint/Aura/Mirage follow the link below...
http://www.youngmonkey.ca/hands/index.html
the crop tool is so much better then it was in Mirage and before.
I think the tool should stay as it is.
A much better Pref setting would be a slider of sorts to set the size of those 'HUD' interface boxes, i think that would make a great preference setting, because it would do so for all tools!
Mads Juul
Post by Mads Juul »
Ok I found a way to reset the Transform tool. it unfortuanately dont work with the crop tool
-mads
dhomas
Re: crop tool woes
Post by dhomas »
I've been using the crop tool a lot tonight, or should I say trying to. It's horrible this way. It is no longer pixel accurate, it's really a crap shoot if you get something cropped to the pixel you intend. It used to snap to a pixel regardless of the zoom, it no longer does, and I'm forever cropping and recropping to get what I intended. Also, the ability to size using the right mouse button (I think that's how it was) was a big time saver. When zoomed in now, it's a real pain in the butt to get to a knob to resize.
