TVPaint Animation PRO here... how to turn on realtime clock display????
In the config.ini file there is a [Clock] section. very first line reads 'display=OFF' change to ON and save ini file. you now have realtime clock display when you start up TVP. how is this accomplished when using TVPaint??? Please advise.
regards,
William
Realtime Clock display
- masterchief
TVPaint Animation Pro v11
- masterchief
Re: Realtime Clock display
can that be issued from inside george script???
I just knew there were MORE secret numbers.....
thank you!
regards,
William
thank you!
regards,
William
- masterchief
I created macro for Shuttle PRO to do it with single keypress
regards,
William
regards,
William
tv_magicnumber 15masterchief wrote:can that be issued from inside george script???
- Clock panel.zip
- Clock Custom panel
- (2.81 KiB) Downloaded 917 times
Hervé ADAM, TVPaint Team
- masterchief
