interface change
- Henk Beumers
interface change
Dear support
My tvp version is 10.5.7 pro.
One week ago, my interface was completely different from the last time I left TVPaint. Nothing was the same. Colors, position of panels. The layer panel all of a sudden corvers both my monitors which is very annoying because things keep appearing behind this panel. No way I can get this panel back to the left monitor where I normally have it positioned.
I tried to set everything like it was before. I saved a configuration but it's not at all behaving like I had it set up before.
Especially when I load a previous project, it appears in the left top corner of the screen not bigger then a post stamp. Every time again I have to readjust the size of my workspace.
It's not the first time something changes overnight.
My daughter who owns tvp 11 has the same issues.
Regards Henk Beumers.
Henk Beumers
TVP 10.05.7 pro 64 bits W7 pro 64 bits. Intel i5 2.67. Mem 16gig.
Re: interface change
Hello Henk,
uuuh we'll need to see a few screenshots for this one I think.
Was any change brought to your monitor's setup inbetween your TVPaint sessions?
Also is your daughter using the same computer as you?
- Henk Beumers
Hello Dean.
No, my daughter is not using my computer. She also uses another OS. W11 on a new laptop. I still work with W7. I used w10 but I don't like it. W7 suites me verry well.
I don't know what a screenshot would tell you.
Henk Beumers
- Henk Beumers
Hello Dean. Attach printscreen went wrong. Try again. It won't work. Normally there is a button. How does this work?
Henk Beumers
Hello, a simple imgur link between the "
" tags will suffice.
- Henk Beumers
This is the printscreen from my 2 monitor setup. In the left top corner there is a little panel with a new project I have loaded. Normally it will load like the second project on the monitor on the right. But also this project I had to enlarge before I could work in it. It loaded like the one in the left top corner. Also the projectpanel is on both monitors as you can see in the edge of the right corner. I had this on the left monitor only and was able to move it or resize it if I needed to. All of a sudden everything changed from one day to the next. Please advice.
Regards Henk.
What's wrong with the simple "attach" button?
Henk Beumers
Attachments > Add Files is working for me.
(click on images to see them larger) My attached image shows up inline like this:
Make sure you are using the Full Editor & Preview mode :
- Henk Beumers
Get it.
Must be me, not visiting this site for a long time. A bit rusty maybe. Can't remember having these issues in the past.
But it's not the answer to the problem I've had lately.
How is it possible that all my settings are completely changed overnight? I stil can't figure out what has happened.
I even reloaded a saved configuration from many years ago but it shows up like the schreenshot I attached.
Everytime again when I startup TVP I have to rearange my setup. Boring.
Can it be a OS thing? I still use W7 because I like it better then the 10 and 11.
Regards Henk.
Regards Henk.
Henk Beumers
Hello Henk, in the "Startup" tab of the TVPaint Preferences panel, what is your "startup configuration" option set to?
- Henk Beumers
Hello Dean.
It's on: "Remember last used configuration."
Henk Beumers
If TVPaint goes back to this panel configuration every tim eyou restart it despite having modified them juste before, this could mean that TVPaint does not have sufficient system authorizations to write new data on your computer (such as a setting change in the config.ini configuration file).
After backing up all your custom brushes and shortcuts if needed, could you try setting TVP's startup behavior to "open the startup panel" and then create a new configuration from there and launch TVPaint with it please?
- Henk Beumers
Hello Dean.
All the best for the next year to come.
Didn't had to much time the last weeks. I read your post again and tried to do what you asked me. Are you sure you respons is for TVP 10?
What could be the reason TVP doesn't have sufficient system authorizations? And where is the config.ini configuration file located.?
Henk Beumers
- Henk Beumers
It didn't toke long to get the next isue.
Henk Beumers
- Henk Beumers
I'm busy drawing in a new project. All of a sudden, out of the blue. Beng. Freeze. No response what ever. Half of the interface is gone.
See image. Complete freeze. Nothing else left to do but reboot computer. Restart. open TVP. This "new" configuration is up again. But I can move the complete window with the mouse. But the weird window I cannot move because the upper bar is out of reach I can't get rid of.
Maybe you can cooke a meal out of it. I'm completely flabbergasted. I don't know how I'm going to finish my work.
I have to find another program to work in because I can't work in an unstable behaviour like this. Hope you can come up with some solution.
Regards Henk.
Wasn't attached to the Internet. Still I scanned for virusses and the likes. No result.
Regards Henk.
Henk Beumers
Hello Henk, did the interface do this out of the blue without pressing any key?
If you unplug one of your 2 monitors and relaunch TVPaint, does the interface reposition?
