Hi there,
I'm trying to export my project (that I had exported fine two months ago), and it is playing an entire minute and 5 seoncds, in about 6 seconds and I have NO IDEA why.
The projects is 1562 frames total, and I'm trying to export it at 24 fps, so it should be: 1 minute and 5 seconds. My export settings are correct - what else is possibly wrong with this?
Very frustrated how simple this should be and how wrong it is.
Thanks for your help.
Cheers,
Garth
Export is playing way too fast no matter what settings I try
Re: Export is playing way too fast no matter what settings I try
Could you post a screenshot of the export panel of this project?
Yes, also a short video of the issue would be very helpful
In addition to screenshots or a screencapture video as mentioned, what video player are you using to view the exported video ? Quicktime Player, VLC, Elmedia Player, DJV Player, or ... ?garthlaidlaw wrote: ↑05 Jun 2023, 18:19
Could it be something in the video player settings ?
Did you ever figure out what this was, Garth? I'm experiencing the same issue. The export is playing double the speed, so the exported video is half the length, but the audio is the correct speed.
Hi, you may want to check your CAMERA PARAMETERS and see what fps the camera is set to as that overrides the export settings. That was my problem for a similar issue.
