Export TVPaint - Import After Effects 1.0.4
Re: Export TVPaint - Import After Effects 1.0.4
Duduf wrote: 31 May 2017, 11:44
Fabrice wrote: 31 May 2017, 11:31 Hello Duduf,
Did you receive my private message and/or email ?
thx :)
I replied about an hour ago (email) ;)
not received, not in spam folder either.
ok, received.
ivisser
Post by ivisser »
Duduf wrote: 31 May 2017, 11:04 Did you try te re-export from TVPaint, or did you try to import the same export as before the update to Yosemite?
And what version of the script do you use, the one from the link in the first post of this topic, or the recently updated one I've posted a few days ago?
Thanks for the quick response!
It does export the project I've exported before.
But it did not export my new project or even the standard one-layer / one-frame new project.
I've tried both versions of the script: namely 1.0.3 and 1.0.4
However I've tried renaming my layers and it worked!
I'd named the layers like this "100_shadow" and changed it into "Shadow_100" and now it works!
So maybe a tip for naming your layers: don't start with numbers :)
Thanks again for your help!
Mads Juul
Post by Mads Juul »
Hi Duduf
I tried to download the newest script , So I can put it in the first Post of this thread.
But the link is not working.
http://duduf.com/downloads/duik/TVPaint-AE.zip
Best Mads
Hi there,
Regarding the After-Effect export, I just wanted to inform you that after receiving requests from various clients a few months ago, we developed our own code and scripts.
We included a lot of features like BG colors, blend modes, instances timings, camera movements, post behaviors...
but at this time, we were unaware that Duduf was still improving his work.
You should enjoy this new export method in the v11.5, under the "Clip structure" Export tab.
Clément
Post by Clément »
Hi everyone,
I'm Clément, i work as a full-time developer at TVPaint. I'm the one who made the latest Import script for After-Effect Fabrice was talking about.
You will be able to try it soon in the next release, so it will be before the version 11.5 :) (to be clear, it will be in the next 11.0.x)
I welcome any suggestion you may have about the script, so do not hesitate.
Clement Berthaud, Software Developer, TVPaint Team
daninski
Post by daninski »
Fantastic news!
http://www.daninski.com
daninski
Post by daninski »
ah, I see... .json
roger_maus
Post by roger_maus »
Hi there!
I installed the scripts in both TVpaint (9.5.3 and ) and AE (CS6). I don't get the export from TVpaint done.
When I hit the "Export AFX" button in TVpaint, it says "Please save TVP project to export clip to After Effects".
I tried saving via File>Export Clip and File>Save Project, which creates a .tvp- or .tvpp-file. But no PNGs, no clipinfo.txt file.
Can you help me? What's my mistake?
roger_maus wrote: 31 Aug 2018, 11:52TVpaint (9.5.3)
You should update your TVPaint version first.
Go to the Help main menu, then click on Check for updates. Your browser will open and should let you download the last v9 version :)
gcassuto
Post by gcassuto »
Clément wrote: 30 Aug 2017, 15:01 Hi everyone,
Hey guys, Hi Clement,
I tried sending you a DM a while back but it seems it never left my outbox. Strange.
Very old topic but just thought I'd mention that I found (I think?) a mistake in the Json script that's importing TVpaint files in AE that you wrote -
Line 633, the comp duration is calculated as follows:
var compDuration = parseFloat(compImageCount) / parseFloat(24.000038);
but the comp duration depends on the framerate (which is exposed earlier in the script)
var compFramerate = ReadFloatFromData( dataTree, "project.clip.framerate", 24.0 );
Currently, if your framerate isn't 24fps, the duration of the comp created by the JSON script won't be correct. This variable should be calculated as follows:
var compDuration = (parseFloat(compImageCount)/parseFloat(compFramerate))
Let me know if I'm mistaken!
G.
Matthieu
Post by Matthieu »
Hi!
Thank you for noticing this, it seems to be a mistake indeed! We're going to run some tests with this modification :)
Clément doesn't work here anymore by the way.
Hironori Takagi
Post by Hironori Takagi »
I have addressed this issue before.
viewtopic.php?f=10&t=13371
Matthieu
Post by Matthieu »
Indeed, we’ve missed it... Thank you very much.
