When you inactivate a layer that layer turns grey.
So does the activate/deactivate button.
I have found myself not seeing the inactivated button so quick when scrolling through the layers so I think a red button instead of the grey would make more quickly find the inactive layers faster.
/ Mattias
inactivate layer switch button
- hellofilms
Windows 11 - TVpaint Pro 11.7.4 & 12.0.2 .- Wacom cintique 24 Pro
- Animationriver
Re: inactivate layer switch button
Yes
- schwarzgrau
I made some icons, which you have to swap manually, but if you use them the indicator is green and red.
http://forum.tvpaint.com/viewtopic.php? ... 539#p83539
- hellofilms
Thanks,
How do you "install" them?
/ Mattias
/ Mattias
- schwarzgrau
To be honest I can't remember. There has to be some TVPain folder, with the same images in it in you program folder. Just make a backup of the original files (just in case) and copy my images into this folder. Unfortunately I'm on macOS, so I can't tell you what this folder is called exactly.
- hellofilms
Ok,
I give it a try.
It worked fine.
/ Mattias
I give it a try.
It worked fine.
/ Mattias
